Hi, on linux mint 18.3 64bit, I was running sh3d 4.5 (included in the normal repos of linux mint) but uploaded a template with inclined wall wich prompted me that there was a newer version.
I dowloaded the 6.1.2 version and at first, i crash telling me to uptade my graphic card driver to latest (but still, was openning, showing plan, but crashing after I clic ok).
Tryed to uptate to nvidia 430 driver, destroyed the systeme, finaly made it back tu 418 (wich seem fairly recent) try SW3D again, no error message but it stuck on logo start up.
I open it from terminal, witout any error message (i just seem ton hang...) no cpu usage of anything...
help would be much apreciated [:D]
Installation latest version not working
This topic has been viewed 7213 times and has 6 replies
Re: Installation latest version not working
Ok, so i updated all and try again, this time it load past the logo (yay!) but then crash saying to update driver (I am a the latest 418 nvidia, on a gtx1060)
here is the prompt from command line
./SweetHome3D com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7faa00245b80, context 0x7faa00478d78, drawable X11OnscreenGLXDrawable[Realized true, Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@733a067, Handle 0x4200097, Surface JAWTWindow[0x67c3ab67][JVM version: 1.8.0_202 (1.8.0 update 202) JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 737 x 374 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x4200097, surfaceHandle 0x4200097, bounds [ 0 / 0 737 x 374 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 737x374], pixels[scale 1.0, 1.0 -> 737x374], visible true, lockedExt false, config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0], chosen GLCaps[glx vid 0x28, fbc 0xaf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28], encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7faa00245b80, owner true, JAWTToolkitLock[obj 0x4a06c94, isOwner true, <26af6174, 3c05cd5e>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0xaf, requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], chosen GLCaps[glx vid 0x28, fbc 0xaf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]], awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,737x374], surfaceLock <2f6f00b8, 41d4519>[count 1, qsz 0, owner <J3D-Renderer-1>]]] at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393) at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586) at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386) at javax.media.j3d.Renderer.doWork(Renderer.java:881) at javax.media.j3d.J3dThread.run(J3dThread.java:271) Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2) X11Util: Open X11 Display Connections: 2 X11Util: Open[0]: NamedX11Display[:0, 0x7faa0002c920, refCount 1, unCloseable false] X11Util: Open[1]: NamedX11Display[:0, 0x7faa00245b80, refCount 1, unCloseable false]Re: Installation latest version not working
ok forget about it! the java version is working... =)
ok, sorry =( can't figure out how to put as solve?
Great you could find out, even if I’m not sure about what you mean by "java version is working"...
FonsCarver
- Country: USA
Hi...I have LM-MATE v18.3 on my antique system, and SH3D v5.6 runs fine. I cannot claim to have extensive experience with the program, and I have not done anything that would qualify as serious work with it, but I have played with it on several rainy weekends.
thank you, thats just what i wanted to know
