Strange "shadows" in 3D view
This topic has been viewed 4332 times and has 7 replies
Fintan
Post by Fintan »
Hi all
Maybe this is covered somewhere else already, but I could not find it.
Anyway when in 3D view and at certain side view angles, I get these strange trianggular "shadows" coming out of the floor and going to a wall.
I would upload an image if I could.Instead here is the droppbox link:
https://www.dropbox.com/s/9p8cmsmhhe8my ... 1.png?dl=0
Can someone please point me in the right direction? I cannot finish this project without solving this issue first.
Cheers
Fintan
Re: Strange "shadows" in 3D view
Post by VeroniQ »
Hi Fintan,
I suppose it's a question of ceiling. Try to remove it and see what's happen. If you need it at some places, create a new room and display only the ceiling.
Fintan
Post by Fintan »
Thank you Veroni
That did the trick. But wny I wonder?? Cheers anyway!
Ceilings cause this problem when not all the walls have the same height.
Possible solutions:
- Try to draw a room by hand using only walls with the same height.
- Split a room in two or more smaller rooms if not all walls have the same height.
Fintan
Post by Fintan »
Thanks Hans. so, in this case I would have to build the terrace as a separate "room" then add it on to the main Rooms?
Imagine you have an L-shaped room. One leg has higher walls, and thus a higher ceiling, than the other leg.
By hand draw a room in the first leg, than draw a second room in the other leg
Fintan
Post by Fintan »
Right. Ok. Cheers
bkdroid13
Post by bkdroid13 »
Cool. thanks for sharing. its helped to me
