Rooms Surfaces plug-in
This topic has been viewed 21382 times and has 21 replies
enkonyito
Re: Rooms Surfaces plug-in
Post by enkonyito »
Hi Dorin,
I tested your plug-in on Windows 10 64bit and it works as it should.
Nice work!
EnkoNyito
Same for me, also Windows 10 64 bits.
Post by bdfd »
@dorin : TY for your return.
I'd installed your plugin with double-click, no problem, it appears in options.
I did 2 tries :
1. with a new project, I built 5 Walls for 2 rooms, after I choose the option… Watch the result (?) :
The plugin is 'grey', Why ? [:((]
2. with an existing project,
The option is NOT 'grey' but by clicking on it there is no result ! [:(]
Watch the options of my PC for SH3D.
@Manu : I try to create a log file but the file is empty !
NB : I say that I use many other plugins (see the list) which are OK, why not these two ?
dorin
Post by dorin »
@bdfd
From what I see You've right but...
I don't know what to say.
Only think that cross my mind is the 1-st suggestion I've propose.
In this way You could test everything on a clean medium.
At least for me is the best way I use when I test new furniture, texture or plug-ins.
It's possible to interfere with other plug-in but I have almost the same as You installed (except Meta text) and I don't see any problem.
Sorry man, I reach my skill's limits.
dorin
Post by dorin »
@bdfd
Sorry if I boring You but I can't sleep.
I've compare what You have with mine:
Image Image
1. I see an very huge plug-in Koping (8.5M). I try to find it on google without success.
2. In second image I share my plug-ins folder and the way I use when I test something.
I create an folder under plugins (mine are "Rezeva" which mean "backup" ) where I put the files I don't use everyday and I don't want to delete.
Usually I drag-and-drop from an location to another.
SH3D will see and load only those from plugins nothing else.
If You can, please send me the link of Koping.sh3p and the source cod if it's free.
Happy Easter!
Dorin
Post by bdfd »
TY Dorin.
Here are my installing plugins.
My last try : I moved all plugins in a backup directory except your.
I launched sh3d.
Result : no change ! [:((]
dorin
Post by dorin »
New version 1.2 and also on Source Forge
-add localization (only French);
-add icon;
-now work including on new file after room creation;
@bdfd
You've right, on some localization don't work.
I've try to fix it in this version.
@UbuntuBirdy
I intend to add perimeter and walls surface surround rooms
with and without hols (doors and windows) to have more useful information.
But all under the same check box.
Bubblobill
Country: Australia
Feature Request - Re: Rooms Surfaces plug-in
Post by Bubblobill »
I want more.
Why? Because what you have almost does what I want and I don't want to write it myself.
What do I want?
  1. A breakdown of area values,
  2. The ability to create a list of key/value pairs,
  3. The capacity to multiply any given area by one of those values, and
  4. The resulting subtotals.
    [/list=1]
    Why should you do it? Because it would be awesome useful.
    Follow me here;
    [b][i]Key value list[/i][/b]
    Ceiling paint             0.1 l/m^2
    Ceiling paint (wet area)  0.13 l/m^2
    Render                    0.8 kg/m^2
    Paint Primer              0.011 l/m^2
    Red paint                 0.019 l/m^2
    Red paint + primer        0.03 l/m^2
    Carpet                    59 $/m^2
    [b][i]                      Area   Material            Result[/i][/b]
    Room Name  Ceiling  32m^2  Ceiling paint        3.2 litres
               Floor    32m^2  Lineolem             $940
               Wall 1   12m^2  Red paint + primer   0.36 litres
               Wall 2   12m^2  Red paint + primer   0.36 litres
               Wall 3   12m^2  Red paint + primer   0.36 litres
               Wall 3   12m^2  Wood Panel           $390
    [b][i]Material             Total[/i][/b]
    Lineolem             $940
    Red paint + primer   1.1 litres
    Wood Panel           $390
    There are obviously a multitude of ways to summarise and present the results, but I'm hoping you can see the value to people who use SH3D to plan renovations and decorating.
    Cheers,
    Jay
dorin
Re: Feature Request - Re: Rooms Surfaces plug-in
Post by dorin »
Dear Jay,
Well, why not? You are bather than me! (I've study Your code for stairs).
Other wise You will have to wait until I manage to learn how to do this.
At that moment I still working to add walls surfaces which surround each room without holes.
The perimeter I've implemented but I'am not fully satisfied.
According to this I what to change the plugin name in "Rooms Info".
Follow me here;
I've follow Your demands and I've see:
The next step is to have some walls surfaces as accurate as possible.
I want more.
Me too but I don't know when.
I weren't good enough to convince Santa to make me such gift [:((]
Bubblobill
Country: Australia
Dear Dorin,
My stairs code might be pretty but your abilities have one important difference. Your plugin works.
I shall write him a letter to tell him how much you deserve it.
