Sash openings
This topic has been viewed 14291 times and has 27 replies
Country: UK
Sash openings
Post by Mike53 »
Hi
Help needed to figure out how to show window openings on the 2d window, something like this :-
After reading OKH's very thorough explanation i am none the wiser, does anyone know of an idiots guide or video.
I have created a range of 5 double glazed windows and 10 doors, interior, exterior and patio which i would like to share but would prefer to do so with the sash openings showing.
Hopefully
Country: UK
Re: Sash openings
Post by Mike53 »
As you can see i am not great with numbers [:))]
Country: UK
Re: Sash openings
Post by Mike53 »
Think i found what i was after HERE .
Thank you OKH and Hafsteinn.
Now to try it.
Re: Sash openings
Good luck. Sash windows would be a welcome addition and useful in many regions where they are common. Looking forward to seeing the result.
PS: When I get the time, I really want to update a guide with separate sections on SVG cutouts, light-sources, hinges, softening/shrinking models, planIcons glass properties, and so on. But as SH3D has evolved with lots of extra possibilities, there are quite a few features worthy of attention. ok
Country: UK
Re: Sash openings
Post by Mike53 »
HI ok good to see you back, hope all is well.
So far....
managed to create a library file and set it so sh3d can use it, well pleased at accomplishing that alone, but when trying to figure out sash x and y i realised that all my windows and doors swing to the left not the right, if you'll pardon the pun.
I went to my library entries to mirror them and found that they are no longer modifiable, not italics either, do i need to re-import them mirrored, or create another sh3f, also, double openings, left and right....jeez.
As for actual sash windows mate, i have not made one but as you mention it i will.
The windows and doors are probably too complicated to be modified to "open", too many parts, especially the double glazed units.
Country: UK
Re: Sash openings
Post by Mike53 »
Any chance someone could post examples (extracts) of the properties for a double opening window.
thx
Country: UK
Re: Sash openings
Post by Mike53 »
Right, forget all that, i give up, 8 hrs of my life wasted and i will have to recreate the sh3d file yet again as it has disappeared yet again, with no exaggeration this is about the millionth time. [:(] .
As for creating a Sash window.....
It is double glazed and no light weight at 1152
Re: Sash openings
Sorry Mike for not answering earlier.
If you have two sashes, you have to cite a pair of values in [font=courier new]doorOrWindowSash...[/font] properties like in this example posted by okh or some double windows available in the default library.
doorOrWindowSashXAxis#15=2 130
doorOrWindowSashYAxis#15=25 25
doorOrWindowSashWidth#15=63.5 63.5
doorOrWindowSashStartAngle#15=0 180
doorOrWindowSashEndAngle#15=-90 270
Country: UK
Re: Sash openings
Post by Mike53 »
No worries mate, i had a feeling this would be beyond my pea brain.
sh3f is again sorted, if i send it to you could you please put the license details in or is that not where it goes
Re: Sash openings
First - windows look great!
As for "..8 hrs of my life wasted..." I am no so sure. If I were to count that way, I would have given up on SH3D long ago. Sometimes, you can spend hours trying to figure out little details without getting it right. I have countless examples. Not only SH3D by the way, it could be building a bunk / cupboard bed (in real life) as I am doing this week-end, or my own metier for that matter... But trying and failing - even when overwhelmed by the latter - is never a waste of time.
And again - the windows look absolutely perfekt!
Users browsing this forum: Amazon [Bot], Baidu [Spider], DuckDuckGo [Bot], Semrush [Bot]
