What happened to the floor?
This topic has been viewed 4808 times and has 11 replies
ottertooth
Country: Canada
Post by ottertooth »
House with 4 levels (incl basement). I have drawn the upper apartment (the 3rd floor) with all the walls and features, including the stairs that go down to the 2nd floor. I created a level below the upper apartment. The stairs end up there and are viewable in the 3D pane. So far so good. But when I drew some walls on the 2nd floor, in the stairs landing area, the floor/ceiling between the 3rd floor and the 2nd floor disappeared. How do you put the floor back in? Adjusting the height of the walls doesn't solve the problem.
Re: What happened to the floor?
Impossible to help you if you don't share your design...
ottertooth
Country: Canada
Why? Most threads here don't have pictures. What do you need exactly? The file?
An image is often more meaningful than some words.
Anyway... I think that selecting the 3D view > Display all levels menu item might help in your case.
ottertooth
Country: Canada
In '3D View' in Menu it already has the "Display all levels" checked.
There should be a floor, so I shouldn't be able to see the bottom of the stairs. I shouldn't be able to see the doorway, because it is below the floor. I looked in one of the demos. You have a 3-storey house demo. There are floors in it. You can't see through them. But when I started adding walls to the 2nd floor in mine, the floor/ceiling disappeared.
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
And have you added floors too?
Pascal
ottertooth
Country: Canada
No, I don't know how. That's my question. What else do I need to say, I've even posted a picture that shows the problem... Floors appeared automatically as I was drawing the top apartment. When I started drawing the 2nd storey apartment, the floor that was already there, disappeared. I don't see any option for adding floors and am not seeing anything about creating floors in 'help'. I just see how to adjust floor thickness. But I can't do that when there's no floor to begin with.
Post by VeroniQ »
This thread will give you some advice to share your picture. About your floor, are you sure you create a room before?
ottertooth
Country: Canada
Thank you, but that is exactly what I did to post the image. For some reason the thumbnail indicates a dead link. But it isn't dead. You have to click 'copy image' and paste it into a new tab.
No, I didn't create any rooms. I simply drew the walls and added 'furniture' afterwards.
UbuntuBirdy
Ok, we now have found your problem. And HERE is your solution.
Pascal
