Top category library
This topic has been viewed 2195 times and has 4 replies
Larz2
Country: Denmark
Post by Larz2 »
I have built a new furniture library with a new name. How can I make this library be current / top category, when opening SH3D?
As it is now, the current category is "All" (Preference setting: Furniture catalog view: Searchable list).
Thanks in advance!
(SH3D version 6.0 on Windows 7)
Re: Top category library
This can’t be changed.
Larz2
Country: Denmark
Post by Larz2 »
OK thanks Puybaret.
Is it possible to delete or remove libraries, which will not be used, from the category list?
dorin
Post by dorin »
The "category" are parts in a "library".
In furniture window You see only the category from all installed libraries.
You could do one of this:
-remove the entire library from home folder (including those with pieces You need)
-edit the PluginFurnitureCatalog.properties files in every library.(e.g. I have 50+)
Anyway almost everything is possible if You relay want (not all are easy).
Larz2
Country: Denmark
Post by Larz2 »
Thank you for your tip Dorin, I will try to edit the list of libraies.
Best regards,
Lars
