I just found out with the help of @okh that it is not possible to input a value, say +5' (five feet), as an offset value in the X-Y coordinate fields of the Modify Wall dialog if application preference is set to Foot/Inch/Fraction.
You can see the discussion here:
Draw (offset) Wall from Existing Wall?
Why would this be available for Metric and Inch/Decimal but non-functional in Foot/Inch/Fraction?
Thanks in advance,
Delain
Need ability to input offset value in Foot/Inch/Fraction data fields
This topic has been viewed 5093 times and has 7 replies
Re: Need ability to input offset value in Foot/Inch/Fraction data fields
Because the metric system doesn’t need ' and " characters. If you use Inch/Decimals unit, you’ll be able to enter mathematical expressions too.Why would this be available for Metric and Inch/Decimal but non-functional in Foot/Inch/Fraction?
If so, I would use (7*12)+11 to insert 7 feet 11 inches (with inch/decimala in preferences). However, that does not give me 95 as expected. Am I missing something...? ok
hi OK
If you input this formula (7*12)+11 into the "modify wall" dialogue box, then the wall moves, for some reason, 18'8 3/8", 224.37". Whereas if you enter the formula into the "move selected item" dialogue box it does then move 95"
Have to ask, would it not be simpler, and it seems to work, using x as its original position inputting x+95
224.36 = (7 x 12 x 2.54) + 11
and 2.54 cm = 1 inch
There must be a conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter! [:(]
Absolutely. My experiment was just to test the math-formula and show how to enter feet/inches with a cheat. Come to think of it, the easiest would be if everyone used metric [:)]..would it not be simpler, and it seems to work, using x as its original position inputting x+95...
Oh well, I guess the math function may have to wait one release in the non-metric world. ok..conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter...
The bug was fixed in version 6.1. Thanks for your patience.
