After a successful install an use I tried to import a new image (the chimney)
sH3d crashed trying to achieve the import.
Since then I can't use it anymore
when I try to launch it from the command line I get the following error message :
yann@Gouelan:~/.SweetHome3D$ javaws SweetHome3D.jnlp
netx: Spec version not supported (supports 1.0)
I tried to reinstall from the web site but it did not work
Any idea ?
thanks in advance
Config : Sh3D 2.0 - Ubuntu 9.04 - JRE 1.6.0
SweetHome does not start anymore
This topic has been viewed 22426 times and has 3 replies
Re: SweetHome does not start anymore
Check your path and which javaws command you really use.
This error indicates that you try to run the javaws command that belongs to a Java 1.4 distribution, and not Java 1.6+ distribution.
I hope this will help.
Hi
my javaws is located in :
/usr/lib/jvm/java-6-openjdk/jre/bin
in the same directory as java :
yann@Gouelan:/usr/lib/jvm/java-6-openjdk/jre/bin$ ./java -version
java version "1.6.0_0"
OpenJDK Runtime Environment (IcedTea6 1.4.1) (6b14-1.4.1-0ubuntu7)
OpenJDK Client VM (build 14.0-b08, mixed mode, sharing)
should I try another java environment and if yes which one ?
Thanking ou in advance
