create sh3f library
This topic has been viewed 4159 times and has 8 replies
morellik
Country: italy
create sh3f library
Post by morellik »
I have a lot of objects to load in Sweet Home and I don't want to do it "one by one". Is there a program I can use to create a library sh3f ? Thank you.
Re: create sh3f library
morellik
Country: italy
Post by morellik »
All OK, thank you.
Lesni
Country: USA
Post by Lesni »
To use this Editor, must I install Java?
My employer has restrictions on unauthorized programs.
Is there a way to have this as a plugin rather than stand-alone.
You must have Java somewhere, installed with an installer or copied from elsewhere.
The Furniture Library Editor doesn't exist as a plug-in.
Lesni
Country: USA
Post by Lesni »
Thanks,
I found the javaw in the bin folder.
Using the command I can start it.
Lesni
Country: USA
Post by Lesni »
In Sweet Home 3D I put an ini file to make the rows and columns readable. Is there one for this program also?
If you have a HiDPI screen, install Java 10 or 11. That will fix the issue.
Note that the ini file used for this purpose with Sweet Home 3D isn’t necessary with version 6.0, and I’ll be happy to know how it works for you.
dorin
Post by dorin »
If You've already import the furniture piece-by-piece (name are shown in italic), You could save all in a personal furniture library which could be loaded when needed.
1. Install the ExportToSH3F-1.0.sh3p plugin;
2. In menu: Furniture > Export imported furniture to SH3F...
Note: Sometime You need to make fine adjustment in PluginFurnitureCatalog.properties file.
