cylinder mod?
This topic has been viewed 2269 times and has 4 replies
Country: UK
cylinder mod?
Post by Mike53 »
Does anyone know if its possible to make the cylinder, available from the library, into a circle?
Country: UK
Re: cylinder mod?
Post by Mike53 »
Ring is probably a better description than circle.
Re: cylinder mod?
Mike,
The cylinder from the library is defined in three parts. If you make top and bottom invisible, you are left with a ring. Note that the wall thickness will be zero.
Country: UK
Re: cylinder mod?
Post by Mike53 »
Thx for the reply Hans, not quite what i wanted, :-
cylinder 40mm diameter 1.2m long, then give it an arc 180 degrees (like a wall) and put 2 together - Ring.
Could not figure anything out with sh3d so i used sketchup.
It was to be used as a round edge on a worktop, the island in my last kitchen
thx again m8
Country: UK
Re: cylinder mod?
Post by Mike53 »
Maybe put the idea of an arc for the box and cyl in wish list ????
