Rename furniture
This topic has been viewed 16460 times and has 17 replies
Re: Rename furniture
Thanks, Enko, works perfectly!
- bdfd
Excellent into a house but just a remark :Version 1.4
Improved treatment.
Why does the tool include objects outside buildings ?
Garden, trees, sidewalks,...
It's not necessary. [:D]
- bdfd
Update : it was only on exterior Walls (gutters, windows, doors,...). [:D]
@bdfd
This therefore depends on the position of the furniture in relation to a room, regardless of its type of environment (indoor or outdoor).
The plug-in adds to the name of a piece of furniture only the name of a room in which the center of the furniture is located and one of its corners with a margin of 1cm.Why does the tool include objects outside buildings ?
EnkoNyito
- bdfd
Ok for these explanations. [:)]@bdfdThe plug-in adds to the name of a piece of furniture only the name of a room in which the center of the furniture is located and one of its corners with a margin of 1cm.Why does the tool include objects outside buildings ?
But I didn't understand for these... [:-/]
I used plugin v1.4
Case 1
The room has a name : 'Master bathroom'
But the window has no name and NO named group ???
=> all furniture below in the list are in same case…
Case 2
The room has a name : 'Bedroom 2'
But the window has no name and without named group ???
Case 3
The next room, nearest of previous anomaly has a name : 'Bedroom 3'
It equipped of the same window.
The window has a name like the room ! [;)]
Can you explain us which is different ?
Regards,
bdfd.
Illustration with the Studio demo file.
before
after
As you can see, the 4 doors or windows in bold do not have their centers inside a room so they have not been renamed.
before
after
EnkoNyito
As shown in the user's guide , a selected piece of furniture has a rectangular outline (1 center and 4 corners).
Which translates into coding:
So just change the outline of the room to take into account the renaming of the piece of furniture (in bold).
[b]getX[/b]
public float getX()
// Returns the abscissa of the center of this piece of furniture.
[b]getY[/b]
public float getY()
// Returns the ordinate of the center of this piece of furniture.
[b]getPoints[/b]
public float[][] getPoints()
// Returns the points of each corner of a piece.EnkoNyito
- bdfd
Yes, good tip !...So just change the outline of the room to take into account the renaming of the piece of furniture (in bold).
