Wheelchair accessible bathroom fixtures
This topic has been viewed 4672 times and has 2 replies
I am putting together a proposal to combine two adjoining rooms in our cloister (living quarters) area as an infirmary. We do have a monk who is on the far side of 90 and is getting increasingly frail. The bedroom itself is laid out fine but I am looking for models for a wheelchair-accessible, ADA compliant attached bathroom that would be about 8X14 feet. Does anyone have any they would be willing to share?
Re: Wheelchair accessible bathroom fixtures
There is a risk people will hesitate to reply as requirements outside the US may differ and I for one would not want to lead you astray. Here building authorities are very strict and unforgiving if you make a mistake. As for the layout you will find drawings with a general image search for ada+compliant+bathroom which might serve as a starting point (Import background image).
When it comes to fixtures, it depends what you are looking for. Maybe the discussion in thread 5717: Disabled adaptions can be of help, but note that wet_room.sh3d in SF 346 is not HC specified - even if it has a floor shower drain and indicates (local) dimensions for a wheel-chair. In addition you will probably need a higher toilet, special sink - and lots of railings.
Some of the Free 3D models can possibly be adjusted to HC compliance, but elsewhere online, I guess you shall find quite a few ADA compliant models. Searching 3D Warehouse for ADA compliant (or something) could be a good place to start.
Good luck.
Good luck.
Thank you for your help. That gives me several good ideas and I appreciate that.
Cordially
Br. Bruno
Cordially
Br. Bruno
