Angled walls
This topic has been viewed 13393 times and has 7 replies
evil_twin
Country: CZ
Angled walls
Post by evil_twin »
Hi, I'm new here and first of all I'd like to say what a brilliant piece of software this is, being an advanced Illustrator and fairly experienced SketchUp user, I was up and running in very little time, very intuitive unlike any other free 2D/3D CAD package out there ...
My questions are:
- how can I draw a wall perpendicular to an angled wall?
- how do I find an angle of an angled wall (generated from a new room drawn based on an imported floor plan)
Also is there a way to draw a wall from a pair of coordinates to naother pair of coordinates? Is there something like magnetic guide lines that can be placed to a particular coordinate?
Thanks in advance for any help or hint.
Wild_Penguin
Country: Finland
Re: Angled walls
Post by Wild_Penguin »
No replies yet, and perhaps someone more involved with Sweet Home 3D will reply.
Anyways I tried to do what you need to do (as far as I understand it) and it seems Sweet Home 3D does not offer tools to do what you need to do directly. Angle information is not available in the wall dialog (and would definitely come in handy sometimes).
If you drag an endpoint of a wall (or click-and-hold, but do not drag if you do not actually want to move it), you can see the angle of the wall.
evil_twin
Country: CZ
Re: Angled walls
Post by evil_twin »
Thanks for a reply and trying. I also need walls whose faces aren't parallel, which is not unusual in older houses in my neck of woods, and which doesn't seem possible with Sweet Home 3D either, so I have to resort to SketchUp. It's quite a shame that the software actually cannot be used unless all the walls are perpendicular or parallel ...
Country: Copenhagen, Denmark
Re: Angled walls
Post by Ceciliabr »
You draw a zero angled wall and then add a perpendicular wall.
Then you select them both an rotate the selection to whatever angle you want.
For walls with unparalleled insides and outsides, you draw them separately (of course!).
AutoCad is a good program for precise architectural drawings.
dorin
Re: Angled walls
Post by dorin »
1. "Definitions of shame
noun
a painful feeling of humiliation or distress caused by the consciousness of wrong or foolish behavior". I think is not correct for a free software.
2. I have some irregular walls on my apartment. I use this trick:
Image Image
Re: Angled walls
Or, maybe just normal drawing will do the trick?
..how do I find an angle of an angled wall...
Using the editing tool (arrow), click on either end of a selected wall to display actual wall angle.
..how can I draw a wall perpendicular to an angled wall?
Use text entering - start drawing wall from somewhere on a wall, press enter, add accurate numbers (add 90° to angle displayed above).
..draw a wall from a pair of coordinates to naother pair of coordinates...
Modify wall dialogue lets you set start and end point of a wall, i.e. co-ordinates.
..fairly experienced SketchUp user...
All of the above are generally easier and faster in SH3D than SketchUp. Once you know how. Good luck.
evil_twin
Country: CZ
Re: Angled walls
Post by evil_twin »
@dorin Sorry for not being a native English speaker, so I guess more appropriate word would have been 'unfortunate'?
@Ceciliabr I used to use Autocad some 30 years ago, so yes, I know. I can afford neither the price nor the time spent climbing that learning curve, I have plenty of those with stuff like coding.
@everyone Thanks a lot for the tips
I still appreciate how easy SH3D is to get up and running compared to pretty everything else, and I know not everything can be made completely intuitive, so it's great there's a place like this forum where one might ask questions and expect useful answers : )
Xlance
Re: Angled walls
Post by Xlance »
from sweethome3d to autocad
saveas .svg > open in inkscape > saveas.dxf or .dxf v12
https://mydxf.blogspot.com/2008/11/inks ... f.html?m=1
_________
from autocad to sweethome3d
load cad2walls.lsp inside autocad > export as cad2walls.input.txt >
use cad2walls.jar > saveas cad2walls.output.sh3d
https://sourceforge.net/p/sweethome3d/plug-ins/56/
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
