mtl problem
This topic has been viewed 3331 times and has 2 replies
Roberto_Taglioretti
mtl problem
Post by Roberto_Taglioretti »
when I try to import this simple file as furniture
http://www.proloco.net/pvertvetro.zip
the error message is:
Invalid format.....
The file is made with aoi ad esposted as obj with mtl.
Someone understand the problem ?
Re: mtl problem
It doesn't work because the material you created has no name. In the MTL file, a name is supposed to appear after the "newmtl" keyword, and in the OBJ file, that name is supposed to appear after the "usemtl" keyword.
pencilart
Re: mtl problem
Post by pencilart »
Yes, as Emmanuel said, name your texture/material from within AOI and then re-export it.
(Just in case you need this):
From the top menu bar, go to Scene > Textures and when the dialog box pops up, click on the texture you want to change and click Edit. Then you can name it.
When you re-export it, the name of the texture should now be there and the file should work.
