love struck Thoughts about roof-plugin
This topic has been viewed 84990 times and has 34 replies
youseeus
Re: Thoughts about roof-plugin
Post by youseeus »
I would suggest that you request to draw this line in a clone of the current home that will display only walls. You could display this clone in your dialog box with your own plan component / controller, using subclasses of PlanComponent and PlanController classes (VideoPanel class uses for example a subclass of PlanComponent).
Thanks for the suggestion :) I think this approach could be used in a future version. One of my main goals is, to store the roof-model (the gabels and the properties, so you can recalculate the roof after adding some jutty) so it would 'survive' to be opened and saved again by a blank SH3D (no plugins). i didn't get familiar with the saving process so i'll follow the first approach for my MVP.
I currently created custom components for my roof, and i do have a dormer that "cuts" half of the roof to create space for a big door window.
This dormer has a gabel. So just add the gabel.
To join Roofs is one of my main goals... so 'checked' [:D]
I would also point out that usually (at least here where i live) roofs extends over the walls and covers also the outside!
i called this feature overhang. It will be part of the MVP
youseeus
Post by youseeus »
If someone want to get involved... i created a private repro at bitbucket, but i can add everyone who is interested. If the first version is finished i'll open that repro.
youseeus
Post by youseeus »
i confused gable with ridge in all of my posts [#-o]
clentl
Post by clentl »
This is great idea . I used to design pools using pool studio and it had great auto roof maker. I'm really confused by this program doesn't have it. I think even the sims 1 had an auto roof...I hope you get this finished!
Gildaniel
Country: Russia
Post by Gildaniel »
Hello!
Some ideas about roofing:
1. Draw roof on plane view point by point by polyline, then feature create projection of it on needed angle with specified roof tickness
2. I'm not sure if this logic easy to implement to SH or not, but roof could be created with frontal sloping walls.
Big bonus of this - standard windows could be used as roof window.
Now if i need roof with windows - I create wall (adjust ens heights if needed), put window there, copy as a furniture, paste and adjust needed angle. But I need to do it many times, because very hard to find good heights and lenght after angled.
So, use case: draw wall, adjust up and lower heights and set needed andgle. After I can adjust heights and dimensions in parameters
2. Is it possible to make "adjustable box", tuning it like posing of mannequin?
JustRosy
Post by JustRosy »
If the interior walls are 4" thick and the exterior walls are 6" thick (this is standard in Architectural Drafting), then couldn't the algorithm just automatically snap the edges of a roof to the endpoints of the 6" thick exterior walls, and be set to draw center-lines either vertically or horizontally, so they connect with the longest center line perpendicularly or at an angle selected by the user when right clicking on them?
Xlance
Post by Xlance »
Hello All
If someone has programming experience and still interested in creating a plugin for Roofs, I have 40 sample images + 40 different palettes to import into "Eclipse" to create Java dialogues with
details / dimensions of each Roof Type.
Cheers
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
dorin
Post by dorin »
I don't have BUT
I am.
BUT where is the png and sources for Eclipse ???
Make a zip and put it somewhere to be downloaded.
Don't expect too much from me but who knows??
BTW
Why don't try to give us some codes?
I usually stole it but now I accept it for free.
PS
I'll by You a beer when I meet You.
youseeus
Post by youseeus »
I didn't do much since my last post. (except i built a house 😅) I'm still interested in this plug-in. But my priorities just shifted a bit :) i invested some time on understanding the code. I'm a professional java developer, but at some points i just didn't understand the data structure and -flow.
Xlance
Post by Xlance »
@youseeus
Source code:
https://sourceforge.net/p/sweethome3d/f ... 1007/#b78b
It's a work in Progress, any improvements / suggestions or modifications are welcomed!
