add furniture to home
This topic has been viewed 1729 times and has 1 replies
trandel
Country: South Africa
Post by trandel »
Hi
Having a problem adding furniture. I drag and drop an armchair but the result is a tiny image. When I try to edit its size the result is still very small and the pic is of a cabinet? I am using centimetres and all seemed OK with the walls etc but the furniture seems about 10 times too small i.e. 90cm I change to 900cm to see it.
Am new to Sweet Home and assume I must be doing something wrong??
Regards
Tony Randell
Re: add furniture to home
Hi Tony,
You could have imported a 3D model with small dimensions. If this is the case, did you check then fix the size proposed at the 3rd step of the furniture import wizard?
Users browsing this forum: Google [Bot], MSN [Bot], Semrush [Bot]
