Different floor textures in different rooms?
This topic has been viewed 9431 times and has 13 replies
Per_Jonsson
Thanks for a _great_ program!
Is it possible to have different floor colors/textures in different rooms?
/ Per
/ Per
Re: Different floor textures in different roo
That would be a great addition. I would like that too.
It's not possible at this time.
I'm working on it. Next version should allow the user to change the color/texture of each room individually, and to import additional textures.
I thought of a bit of a work around:
Use the cube that you provided (the box in the Miscellaneous category) and just flatten it. Then apply a different color for each room that you've put it in. However, it would be a problem if the room is not square or has a "bay" area (sticks out with the walls at an angle other than 90º.)
Rooms with their own texture or color were added in version 1.5
Re: Different floor textures in different rooms?
I'm using the 1.5 version but I can't apply different textures or colors to the room's floors. Why? How can I do it? Thanks for this great software.
Create a room with the "Plan > Create room" for each floor you want to change, and then modify the room.
But, when I try to modify the room, I don't obtain any menu, neither double-clicking on it, nor right button of the mousse. How can I modify the floor of each room? Any screenshot to show it to me? Thanks and congratulations for the software.
Ok, I've yet tried it, but when I right click at 2D grid the sub menu pop up, but when I select "Modify Room" doesn't happens. When I right click at 3D View I can modify the main floor (grasp, sky...), but not the room floor. What's going wrong? I'm very desperate.
