I have set up a kitchen and wanted to group all furniture elements. The result is not as I would like it to be. I have a cabinet, a ceramic hob on top of it and an upper cabinet above both. Ungrouped it is shown exact as it should. As soon as this becomes a group (or part of one) the ceramic hob is always shown on top of the upper cabinet. This applies to the twodimensional floorplan only.
Did I make any mistake?
Grouping elements
This topic has been viewed 2602 times and has 2 replies
Re: Grouping elements
It's about the order to draw it.(Look in the furniture list)
The order of insert is: lower cabinet, ceramic hob and upper cabinet.
After grouping will look OK in both (2D & 3D).
If You don't want to redraw all, You can use the cat and paste in same place until realize the needed order.
The same are happen when You insert table before chairs and You want them partially under table.
ipfelkofer
- Country: Germany
Thank you very much.
Of course it works the way you described it!
