how to make an opaque glass ?
Opaque window
This topic has been viewed 2491 times and has 5 replies
- bdfd
Opaque window
Re: Opaque window
By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass? Not sure it's really possible in Sweet Home 3D, but you can try with some glass textures on some transparent material, like in this video at 3'05".
- bdfd
Re: Opaque window
Yes, exactly !By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass?
I did many tries without success. [:(]Not sure it's really possible in Sweet Home 3D, but you can try with some glass...
An idea : I read this morning a fetaure of enko on light about a vertical surface... [;)]
but how make this object ?
Re: Opaque window
Hello, if I understand correctly you want to adjust the transparency of an object
I'm going to change the mtl property of the obj file
is this what you're interested in?
translated google
translated google
Re: Opaque window
newmtl Glass
illum 1
Ka 0.0 0.0 0.0
Kd 0.5019608 0.49803922 0.49803922
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
d 0.9 <---- opaque
newmtl Glass
illum 1
Ka 0.0 0.0 0.0
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
d 0.2 <---- transparent
illum 1
Ka 0.0 0.0 0.0
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
d 0.9 <---- opaque
newmtl Glass
illum 1
Ka 0.0 0.0 0.0
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
- bdfd
Re: Opaque window
Hi Golia,Hello, if I understand correctly you want to adjust the transparency of an object
translated google
It was a good idea but no ! [:((]
I explain :
I did that you said with the mtl file (d 0.975 ).
Directly under sh3d, Yes with a outside screenshot ! [=D>]
Look at the left side...
But in standard rendering...
Outside and without light, opaque propertie has disappeared.
Outside and With light, no difference.
Inside without light, no difference !
Inside with light, same result !
Thank you for your idea but it's not positive... [;)]
