Floor Textures with gaps from lower level walls
This topic has been viewed 2943 times and has 2 replies
k1r2t3n
Post by k1r2t3n »
Hi there,
I would appreciate your help:
I am currently building our new home in sweet home and started to apply textures. unfortunately the textures seem to show gaps where the lower level walls are. see screenshot. What is wrong?
https://www.dropbox.com/s/d59csregk2kk5 ... s.png?dl=0
thank you.
Kirsten
dorin
Re: Floor Textures with gaps from lower level walls
Post by dorin »
What is wrong?
The height of walls in level UG are at least as the elevation of the level EG.
Solution:
Verify the height of walls on level UG and reduce them.
or
Increase the elevation of level EG.
PS Don't forget: every level have a floor thickness; You must take it in consideration.
k1r2t3n
Post by k1r2t3n »
Dear Dorin,
thank you! I added another 1cm to the elevation. This did the trick!
Perfect!
Cheers, Kirstne
