sad Installation Question
This topic has been viewed 4503 times and has 1 replies
KashifSharif
Country: USA
Post by KashifSharif »
I install Sweethome3D on my ubuntu 16.04 by running a Terminal command
sudo apt install sweethome3d
It install the application without any issues but OLD version
Version 4.5 Java version 1.8.0_162 / 64 bit / 1.7 GB ma
I can search and find it and Run it.
I downloaded the latest version SweetHome3D-5.7-linux-x64.tgz. I extracted the file which created a Folder SweetHome3D-5.7.
There are 2 shell script inside the extracted folder. 1) SweetHome3d and SweetHome3D-Java3D-1_5_2.
I can run the application with bash but i am not sure is this the correct way.
I do not know how do Install it or Upgrade on top of old version.
dorin
Re: Installation Question
Post by dorin »
The shell script are executable.
Double click on one of them and answer execute when prompted.
The version offered in repository usually don't run correctly especially with jre9 or jre-10.
You can edit the application menu to lunch from there and associate the .sh3d file ONLY with this great application.
The version from repository You can remove completely and I strongly recommend to do this.
Good luck!
