setSelectedLevel gives an Error
This topic has been viewed 1288 times and has 2 replies
PacWood
Country: USA
Post by PacWood »
I am attempting to select a level in a building via the API.
Below is a snippet of code that successfully runs until
the last line is reached.
         var HOME;
	 var HPC =  viewHome("viewerCanvas",
           homeUrl,
           onerror,
           onprogression,
          { roundsPerMinute: 0,
            navigationPanel: "default",
            levelsAndCamerasListId: "levelsAndCameras",
            selectableLevels: ["Level 1", "Level 2"],
            activateCameraSwitchKey: true
       HOME = HPC.getHome();
       var theLevels = HOME.getLevels();
       var levelName = theLevels[0].getName();
       console.log('levelName: '+levelName);
       var objLevel = theLevels[0];
       console.log(objLevel);
       HOME.setSelectedLevel("Level 1", objLevel);
At the line:
A javascript error occurs, which is:
      "Error: TypeError: m.getElevation is not a function"
However, the code prints the object 'objLevel'
I can see in the console log, the object 'objLevel' shows
there is a function named "getElevation".
Does anyone have an idea why there is an error of
"getElevation is not a function"
and yet there is a function named "getElevation" in the object
that is being passed to HOME.setSelectedLevel() ?
Below is a screen shot of the console output.
thank you for your help.
Re: setSelectedLevel gives an Error
Sorry, the JSDoc of setSelectedLevel isn't clear and will be fixed in the next version.
[font=courier new]setSelectedLevel[/font] takes only one parameter:
HOME.setSelectedLevel(objLevel);
PacWood
Country: USA
Post by PacWood »
Thank you very much for your help and example code.
The program works now.
