I'd like to add a painting to a wall using as texture a jpeg picture of monalisa.
I can import the texture but I get a tiled result. Is there a workaround or I must
create a 3d object outside SH ? Thanks.
tiled texture
This topic has been viewed 4175 times and has 2 replies
Re: tiled texture
You can use this frame , for example, and change the canvas texture with imported Mona Lisa which will apply without tiled aspect. Only mind the proportion.
Re: tiled texture
On the Sweet Home 3D Youtube channel, you will find a tuto to Customize a frame.
