Export to HTML5 plug-in
This topic has been viewed 5091258 times and has 152 replies
Re: Export to HTML5 plug-in
..almost all browsers except Firefox (until now) don't allow to read local files by default, for security reasons!!!
In case anyone wondered, off-line view still works with the apparently re-written Firefox Quantum. Alas, I have yet to find any other browser (except Seamonkey) that will display a test website with the html5 plugin. ok
dubbyconqueror
Country: Germany
Post by dubbyconqueror »
Thank you so much for providing the HTML5 plugin! Would you mind uploading the unminified sources to Github/Gitlab/Bitbucket etc.? That way other people might contribute to the development more easily.
I'm happy you like it [:)]
You can generate the unminified files with the [font=courier new]generatedLibraries[/font] Ant target of the [font=courier new]build.xml[/font] file available in the source code of SweetHome3DJS. I won't copy these files in another repository myself, because this would require to update it too and managing the release of each version in one place is already a quite heavy task.
qythyx
Country: Japan
Post by qythyx »
I tried to use your Blender import script, but it failed. The error was that it couldn't find a file. I'm guessing it was because the file has a space in the name. The error message said it couldn't find "Grand%20Piano.dae.obj". That file does exist, but %20 is a space instead.
Any ideas?
I'm not the author of the Blender import script, but when you know that the 3D model of a piece of furniture is stored in its [font=courier new]model[/font] attribute, it shouldn't be difficult to find the place in the script where the path of a model is used and adapt its urlencoded notation to the one required by Blender. Then don't forge to contribute your fix in the https://github.com/lcgamboa/sh3dtoblender project [:)]
omrico
Post by omrico »
Thank you very much for this remarkable feature!
I was wondering: After integrating the component in my website I am able to see the house in "Aerial View" but the view is centered to the viewer.
Is there any way to programmatically change the position of the "camera" so it won't be located above the center of the house? [:-/]
For example when using the SH3D software, I can click on an object and it gets the focus. This helps me to better look at the surroundings of this object.
Thank you in advance!
Selecting an object of the displayed home should have the same effect as in Sweet Home 3D. From the HomePreviewComponent returned by viewHome, you'll be able to access to the displayed Home instance, which lets you access to all its objects and select the ones you want with its setSelectedItems method.
LBCED
Country: Italy
Post by LBCED »
I try to use it. With Firefox works fine, otherwise with Chrome I have the following error:
"Failed to load <nome file> cross origin requests view model.min.is:20
are only supported for protocol schemes: http, data, chrome, chrome-extension, https"
What I can do ?
You probably tried on a local file, not on a http web server, and Chrome doesn't accept to load local files which depends on the viewed html file. If you host your files on a web server it will work, and if you absolutely want to try your file locally with Chrome, see the solutions proposed here.
omrico
Post by omrico »
I tried what you said but didn't succeed with changing the camera. I fetched all the selected items via
getSelectableViewableItems()
function and randomly chose an object from the array.
Then used
setSelectedItems(selectedItems)
function but the camera didn't change the angle and position. What am I missing here?
Thank you.
