Is it possible to "cut" / Display only a section of a furniture, i.e. windows, at a certain heigh, to align it with a lowered wall / display only the half lower part ?
Being at your disposal.
Regards
Windows half height cut / Display only half of a window.
This topic has been viewed 2450 times and has 3 replies
Re: Windows half height cut / Display only half of a window.
Depending on what you want to achieve, some earlier discussions could be of help:
thread 6997, SF 3d models 399 and the blog post on displaying interiors.
Thanks @Okh ! Helps a lot !
One step further, is it doable with a double doors windows ? (like Scopia's ones http://www.sweethome3d.com/models/scopi ... egular.zip)
Not without editing or creating the door/window in 3D modelling software. But to get an approximation, use the half window in the example above, place two side by side and change colour of Frame1 to invisible, lower elevation and increase height. While it does not look exactly the same, it gives a rough impression of a double glass door cut in half. ok
