Method not accessible from a plug-in
This topic has been viewed 5516 times and has 2 replies
enkonyito
Post by enkonyito »
By checking the compatibility of the PhotoVideoRendering-1.3 plug-in with SweetHome3D-5.5, I get an error after integrating the PhotoRenderer file update.
Error message: "The method getPieceOfFurnitureNormalizedModelTransformation (HomePieceOfFurniture, Node) from the type ModelManager is not visible".
PVR-1.3
SH3D-5.5
Is there a way to circumvent this restriction?
EnkoNyito
Re: Method not accessible from a plug-in
I guessed you would need getPieceOfFurnitureNormalizedModelTransformation, made it public during half an hour, and finally changed my mind because I didn't want that a method with such parameters be part of the API.
Just copy / paste it in your own code.
enkonyito
Post by enkonyito »
At first the solution did not work but with perseverance the problem was solved.
Thank you!
EnkoNyito
