Add a new home property to a change listener
This topic has been viewed 5701 times and has 2 replies
enkonyito
Post by enkonyito »
The setProperty method allow to set a new property associated with a home.
But can this property be taken into account by the addPropertyChangeListener method without returning an IllegalArgumentException if you use valueOf (String name)?
With this code:
this.home.addPropertyChangeListener(Home.Property.valueOf(ENHANCED_EXTERNAL_BRIGHTNESS),
	    new PropertyChangeListener() {
	    	public void propertyChange(PropertyChangeEvent ev) {
	    		isEnhancedExternalBrightness = Boolean.parseBoolean(home.getProperty(ENHANCED_EXTERNAL_BRIGHTNESS));
	    		externalBrightnessEnabledCheckBox.setSelected(isEnhancedExternalBrightness);
I have this error:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: No enum constant com.eteks.sweethome3d.model.Home.Property.enhancedExternalBrightness
EnkoNyito
Re: Add a new home property to a change listener
The method [font=courier new]valueOf[/font] of an enum takes into account only values of the enum that exist.
The main problem comes from the fact that enums are [font=courier new]final[/font], and using enums for these properties is actually a wrong idea I had [:(]
enkonyito
Post by enkonyito »
I wanted to bind the enhance external brightness option of the photo panel to the video panel.
The alternative would be an implicit selection from the photo panel only.
I do not know if other developers needed to add a new home property to existing ones but if there is a solution for it to be possible without too much changing the source code, why not?
EnkoNyito
