A pure 90 degree floor plan render?
This topic has been viewed 4318 times and has 5 replies
thekhan360
Country: India
Post by thekhan360 »
Ok so I am trying to achieve a floor plan in a 3d rendered image rather than the stock 2d pic. What I do is in the aerial view I try to adjust the camera right over the centre of the floor plan and then take the image.
The only major flaw is that the walls right below the camera are appearing as straight line as intended, but due to the angle of elevation, the walls which are farther from the floor plan's centre are showing them selvesmore than intended.
To explain it more clearly, this is what I have been able to achieve:
And this is what I want:
Can some one please help me?
thekhan360
Country: India
Re: A pure 90 degree floor plan render?
Clearer pic:
Post by bdfd »
it does not exist ! [:((]
Either it is the aerial 3D view, either in virtual view, either it is the plan.
A new request in the wish list... [;)]
If you take the virtual visitor to max height (some 10 000 cm?), head angle to 90° and narrow the field of view to ± 15°, you might get a better approximation. Or, you could export to .obj and try with software/3d viewers that can do different (parallel) projections.
But since what you want essentially is a 2D view with shadows, it is probably easier to apply the shadows to the 2D plan, e.g. like this:
- Check SH3D settings to get the right 2D view:
[font=courier new]- - Furniture icons in plan: top view
- - Room rendering in plan: Floor colour or texture.[/font]
- Select plan and copy/paste to an image editor, such as the Gimp.
- If you use the Gimp, try applying[font=courier new] Filters - Light and Shadow - Drop Shadow / Xach-Effect[/font] to walls and different selections.
PS. You could also export the plan to SVG and edit with Inkscape which also has numerous filters and extensions for different effects. As for the wish list, not a priority as far as I am conerned.
Post by bdfd »
Like I said simply : It does not exist ! [=;]
thekhan360
Country: India
Thank you the both of you but I think I will wait for the devs to prolly look into this feature as a future addition. :)
