ALERT : Win10 build 1703
This topic has been viewed 14752 times and has 33 replies
Re: ALERT : Win10 build 1703
As suggested in my previous post, please try with the Jar executable version.
- bdfd
OK, it's done.
I launched it by double-click on jar file and...
I saw only this :
And no more ?
No log !
I saw only this :
And no more ?
No log !
Even if Java 9 is still in beta version, I wished the program could run a little further [:(]
You could launch the program in a cmd window with a command like:
The logged errors displayed in the console you give some hints to go further...
java -jar path\to\SweetHome3D-5.4.jarEmmanuel Puybaret, Sweet Home 3D creator
- bdfd
Thanks Manu.
Here is the log of the command :
And I forgot the log's file (xxx8304.log) with return on java 1.8.0_51 :
- Attachments
- hs_err_pid8304.log
- (31.32 KiB) Downloaded 40923 times
- hs_err_pid5972.log
- (40.05 KiB) Downloaded 40769 times
- j9log.txt
- (3.3 KiB) Downloaded 60702 times
- bdfd
A new downloading and installation of Win10 build 1703 (15063.138) on a mobile computer (core i3) gave EXCELLENT results... [=D>]
I do same thing on my another desktop !
I don't understand... [:((]
- bdfd
This morning, a new installation of Win10 build 1703 (15063.138) on my desktop (core i7) did not give good results... [:((]
sh3d always crashes... [>:)]
Same thing with sh3d 4.6 & 5.3 !
- bdfd
Do you have any news about my problem seen on apr 07th ? [:(]
I think to make a good diagnosis, you just compare why there are differences between 'Save' (NOK) and 'Save and compress' (OK) actions and find out what can cause these crashes, right ?
We have the effects, you must find the reason... and the solution.
I hope that the last logs are speaking themselves.
As said before, this bug seems to be bound to the file dialog box, and on a brand new document, all menu items Save, Save as, Save and compress as well as Open must crash the application in your case. Is it right?
- bdfd
Absolutely no !As said before, this bug seems to be bound to the file dialog box, and on a brand new document, all menu items Save, Save as, Save and compress as well as Open must crash the application in your case. Is it right?
In file menu
New : OK
Open : Nok
Open recent files : OK
Save : Nok
Save as : Nok
Save and compress : OK
In Furniture menu
Import Furniture, choose : Nok
Import Furniture bib : Nok
Import Texture : choose picture : Nok
Option Create photo
Save : Nok
To understand better , we can write on french section. [:x]
- bdfd
@Manu, more news !
Print in pdf : Nok
Import texture lib : Nok
Export to csv : Nok
Export to svg : Nok
Create video, save : Nok
Export to obj : Nok
Export to html5 : Nok
All other options didn't crash !
[:(] [:((] [:O] [:-&] [X-(]
Print in pdf : Nok
Export to csv : Nok
Export to svg : Nok
Export to obj : Nok
