This topic has been viewed 76274 times and has 59 replies
Thread status:
Active
Posts: 2614 Joined: Sat Mar 29, 2014 7:17 am
Post
by bdfd » Wed Feb 22, 2017 5:48 am
Here are the two new rovers...
1920 x 1080 in Q4 reduced in 1024 x 768
Bigger, faster, with more autonomy and I find it prettier...
And the specifications
AeowynFraser
Posts: 563 Joined: Wed Oct 08, 2014 1:02 am
Country: Lancaster, CA, USA
Post
by AeowynFraser » Wed Feb 22, 2017 7:44 am
I am awed at the creativity that has gone into each of these!
Post
by bdfd » Wed Feb 22, 2017 9:54 am
Thank you Aeowyn, maybe there are many persons in my head ??? [:))]
Here is the
model 3D HERE of this rover2.
Post
by bdfd » Thu Feb 23, 2017 5:52 am
Closer views on the new rovers.
and
1920 x 1080 in Q4
In front of to rover1 (follow the traces), they find the base camp.
Before to use them, they must be charged by the sun... [B-)]
Post
by bdfd » Fri Feb 24, 2017 3:29 pm
D 735 - Dec 2nd 2041
During rovers 2 loading, rover 1 goes to habmod to activate it.
The rest of the team unpacks the boxes and starts using the 3D printer to launch the production...
Post
by bdfd » Sun Feb 26, 2017 6:18 am
D 780 - Jan 16th 2042
To connect all rovers with the base camp, the crews need a new 'building', it's the Roverport.
You are in inflatable section between the Base camp's hangar and the roverport.
450 x 768 in Q4
One time inside the roverport you are in pressurized section.
1024 x 768 in Q4
You must climb the stairs to arrive in airlocks section.
Post
by bdfd » Tue Feb 28, 2017 6:50 am
Three accesses were done:
=> one for rover type 1 (rectangular and telescopic) at right on picture
=> two for rover type 2 (circular) in front and rear.
At left, you go back to the base camp.
1024 x 768 in Q4
You see a marsonaut going out from a rover2.
Post
by bdfd » Sat Mar 04, 2017 5:43 am
The second access for rover type 2 (right side)
For rover type 1.
Inside with the attached rover.
1024 x 768 in Q4
Post
by bdfd » Fri Mar 10, 2017 5:41 am
Outside views of the roverport from the hangar.
1024 x 768 in Q4
You can see thru the inflatable tunnel the two new rovers (front and rear) on each side of the roverport.
Post
by bdfd » Wed Mar 15, 2017 6:45 am
Here is a general south-east view of the roverport connected to the hangar and the cupola with a rover type One and the newer rover type Two.
1920 x 1080 in Q4
