Recalculate Room Points
This topic has been viewed 11520 times and has 6 replies
rhawke
Country: United States
Post by rhawke »
After I move a wall by a few inches or move a door left or right along a wall, I have to update the room. Right now the easiest way is to delete the room and add it again with double click (because fixing the room to match a moved door manually takes a long time).
But then I have to select the textures again, change labels, etc.
It would be nice to have a button inside the "Modify Room" dialog box that lets you recalculate the room points (basically same calculation as when I double click in the center of the room). You could simulate this by assuming I double clicked into the center of the selected room.
Or is there already a good approach to this problem that I am missing?
Re: Recalculate Room Points
I had the idea to add an option to recalculate rooms like you proposed.
But I already introduced a solution to simplify this operation: cut the room, create the room with double click and select Edit > Paste style menu item.
rhawke
Post by rhawke »
Thanks Emmanuel, this is a good tip. I will use this from now on!
For new users the idea to have a button to recalculate would be nice though, so if it is easy to implement I think it would a way to make the software even more intuitive and user friendly (It already is AWESOME!)
Country: UK
Post by Miker777 »
Hi rhawke
Sounds like a good idea to me, i never get door positions right 1st time, or 2nd come to that.
shoulders
Country: United Kingdom
Post by shoulders »
Is this an easy thing to make into a macro attached to a mouse context menu?
thanks
fabiin
Post by fabiin »
+1
I was seeking for the feature described here.
Pasting style does not work for options other than style like room name, display area, label and area position.
Recalculate room points item was added to plan contextual menu of version 7.2.
You have to select a room and right click at a point where the room points should be recalculated to get this menu item. If the points don't need to be recalculated, the menu item won't appear.
