High priority Global illumination doesn't work in virtual visit mode, in aerial mode it's OK
This topic has been viewed 5815 times and has 6 replies
shwaiger
Country: Russia
Post by shwaiger »
Please help! Rendering the same scene with the same render options (max quality) giving different results depending of viewing mode: in the aerial view global illumination seems working, quality OK, but rendering in virtual visit mode gives bad quality picture. What am I doing wrong? I'm using Sweet Home 3d 5.3 on macOS Sierra with latest Java.
I found the same problem on this forum, but there is no solution :(
http://www.sweethome3d.com/support/foru ... hread,5167
There are my renders: in aerial mode and virtual visit:
Re: Global illumination doesn't work in virtual visit mode, in aerial mode it's OK
You're doing nothing wrong, Aerial view and Virtual visit modes don't use the same lighting system, as your captures show it.
shwaiger
Country: Russia
Post by shwaiger »
Can it be changed? Maybe via configuration file or source code? Aerial view's lighting system looks much better!
Country: Copenhagen, Denmark
Post by Ceciliabr »
Have you tried using this renderer? :
CreatePhotoWithRenderer-1.3.2.sh3p
cec
shwaiger
Country: Russia
Post by shwaiger »
Yes, tried, but it looks very bad. Aerial view illumination model much better. I wonder, why not to use this model in virtual visit mode. If someone of developers read this topic, please give me a hint, where to tweak to try switching GI model for virtual visit!
It's programmed this way because it gave better result/performances in most cases using this way. Meanwhile, it's possible that there have been some bug fixes in SunFlow that could be worth being tested, but testing changes in SunFlow is a very long task... [:(]
EvEnger
Country: USA
Post by EvEnger »
Hi, Shwaiger!
Have you found the solution of problem described above?
