Hello Sweet Home Users,
I look for possibilities to put walls under an angle, ie 75 degrees with horizontal. Walls will standard be drawn under a 90 degree angle. Is that possible????
Thanks HobbyBouwer NL
Walls not vertically but under 75 degrees
This topic has been viewed 5447 times and has 2 replies
- HobbyBouwer
- Country: Nederland
Re: Walls not vertically but under 75 degrees
No, it's not possible, walls angle with the floor is always 90°. See this tip if needed.
Hi HobbyBouwer
If you position the walls you require, add windows, doors etc, then export it, on importing you could tip it to 75 degrees. If you do not require doors or windows, then i would suggest using the shape generator, this would enable to create a rhombus, keeping top and bottom surfaces horizontal.
Hope this helps.
Hope this helps.
