SweetHome3D On Surface Book Hi Res Display
This topic has been viewed 13439 times and has 13 replies
[email protected]
Country: United States
Post by [email protected] »
I have a new Surface Book with the 3000x2000 display. I have worked through all of the Hi Res DPI solutions using changes to the manifest file in the program directory. All of my applications are natively or with manifest file rendering properly. Except for Sweet Home 3D. It renders as in the small font mode. The menu items seem to be cut in half. [img]http://C:\Temp04\SweetHome3DHighDPI.bmp[/img]
I cannot seem with any solution to get it to render without this problem. My version was the 5.2 version purchased through Amazon. Also the version from the SourceForge site. And my current version is the 5.3 beta that I installed this morning.
Machine is running Windows 10 Pro.
Re: SweetHome3D On Surface Book Hi Res Display
I'm not sure about what you mean by changing the manifest file. Did you read this thread which explains how to activate the HiDPI support on version 5.2?
[email protected]
I have tried setting the property in the ini file and it did succeed in making the overall display of the elements larger based on the scale that I set. BUT..... the actual menu items still appear truncated. I have screen captures of what I mean but can't figure out how to get them up here. I tried the "image" button but can't make that work...
Is there a difference with and without the ini file?
[email protected]
Hello, and thank you for the reply. Yes, there is a difference with the ini file. But the problem is not solved. Is there a way to put an image up for you to see? The picture would be worth more than 1k words.
Thank you,
Country: UK
Post by Miker777 »
Hi Bob
Have a look at this link to enable you to share your images.
[email protected]
Cannot parse the parameter "thread" to a "int" value! Please try again.
Did you try with the 5 following lines in the ini file?
-Dcom.eteks.sweethome3d.resolutionScale=2.5
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
-Dswing.plaf.metal.controlFont=Dialog-11
-Dswing.plaf.metal.userFont=SansSerif-11
-Dswing.plaf.metal.systemFont=SansSerif-11
[email protected]
YES!!!!!!! Those additional settings did solve the problem. I'm a retired software developer who did code Java for 10 years, but after 2.5 years I'm soooo rusty. Where might I read about those settings. BTW I was mostly IBM WebSphere and container based coding. No Swing experience....
Country: UK
Post by Miker777 »
Sorry bob
I was stuck in a hotel room with just my phone to browse on.
Here is the link
