3D error WIN10
This topic has been viewed 8006 times and has 6 replies
3D error WIN10
Installed sweethome3d 5.2 on WIN10. Installation seems ok. After starting, the program shows up but an error "3D error" (or 3D fout in Dutch) appears.
Re: 3D error WIN10
I have the same problem. I started the program with Java webstart.
Win 7 64 bit
Intel Xeon
Is there also a portable version of 5.2
Win 7 64 bit
Intel Xeon
Re: 3D error WIN10
Sama problem here
Also in the Dutch version....
Re: 3D error WIN10
Also I have the same problem. version 5.2
Installation went well but received the note that my DirectX is not the right version. Have Windows 10 and Dirext X 11.1. Have tried Windows update but they gave the message all is at the latest versions. Please advice what to do.
Version 5.0 on an computer works well.
Re: 3D error WIN10
Please try the version 5.3 Beta 6 which should fix this issue. As this Beta version doesn't contain any new feature yet, you can continue to use it without risk until the final version 5.3.
Re: 3D error WIN10
Very Strange problem !
I installed SH3D on my surface4 , it works perfectly for a couple of time , execpt tiny icons and menus . I found the solution in the threads But before having tried this solutions SH3D doesn't start anymore ? I tried the 5.3 java web start . SH3D starts and stops (direct X Problems ) I'm very disappointed , I need to use and old computer to be able to launch SH3D
A tablet or surface is very useful to have your drawing anywhere on the workshop
Thanks in advance for your help
Re: 3D error WIN10
I finally found the solution
It is due to the windows update The latest version probably a beta one of windows has been installed . I reinstall the win 10 previous version and right now SH3D works perfectly on my surface 4 with the 5.3 beta and HiDPI parameter
Greattttttttttttttttttt !
