I want to create a sketch in which I
I make 3 30 cm high walls (Ytong) and on a "wooden plate" Place.
Can anyone give a tip, have nothing corresponding Found.
greeting
Markus
With google-translator of German translated to English
Put on board 30 cm high walls
This topic has been viewed 3138 times and has 2 replies
Re: Put on board 30 cm high walls
I think i understand, you want a texture to appear as Ytong blocks, if that is so, i believe you can take a photo, resize it in "paint" or "photoshop" and then import it to sh3d as a texture. I think!!!
Hi Markus, sorry, I read your German and English question, but I have a problem figuring out what your problem is. The walls are easy to make, just change them to 330 cm high. Then, you could make a new level 330cm above the first level and use a box (or several boxes) and add wood texture.
But I suspect I may not have understood what you are trying to do... Some more information (in German or English) and it might give you more replies.
