Error 1114
This topic has been viewed 16037 times and has 6 replies
Graedy
Error 1114
Post by Graedy »
I used sh3d version 5.1 (latest version) under windows 7 without any problems. Ever since I updated I get the following error when trying to launch sh3d:
"LoadLibrary failed with error 1114: Eine DLL-Initialisierungsroutine ist fehlgeschlagen."
Java - latest version
GD - latest driver version
I already tried the following things to solve this problem:
1. Under the GD menu "Switchable graphics" I changed the setting for sh3d to "high performance"
http://www.win-10-forum.de/windows-10-a ... chlag.html
2. I reinstalled sh3d under win10
Nothing worked. Any ideas? Let me know if you need any further information. Thanks ind advance.
Re: Error 1114
Did you try the installer version or the Java Web Start version?
ManuFr
Re: Error 1114
Post by ManuFr »
Hi all,
I tried the Java Web installer and I was prompted to associate files with applications.
After that I could start the local installation.
Graedy
Re: Error 1114
Post by Graedy »
I used the installer version. Java Web Start works fine now. Thx.
daniloze
Country: Brasil
Re: Error 1114
Post by daniloze »
Same error here with installed verson.
wbravin
Country: Italy
Re: Error 1114
Post by wbravin »
HELLO ALL
I'M NEW TO ALL THIS.
I downloaded the installer version and updated java 17.
when i go to install sweethome I get the common error 1114.
in searching the net i am directed to change my power setting to maximise.... which i do and the installation proceed normally.
however, if i forget to change the power setting back to optimise and reboot the pc, the pc crashes. I then need to reboot the pc in safe mode to set the power setting back to optimise. This does not successful all the time since last friday i needed to reinstall windows (paid License).
Why do i need to change the power setting and how can i avoid this issue?
thank you in advance for your help in this matter
Daniels118
Country: Italy
Re: Error 1114
Post by Daniels118 »
If changing the graphic settings works, you could do one of the following to minimize the impact on the system:
  1. enable the high performances only for Sweet Home 3D as described here;
  2. if you're running on a laptop you can set high performances only when the pc is plugged.[/list=a]
    The first option is the recommended one. If the first option doesn't work and you cannot reboot the pc when high performance is enabled, the second option give you a chance to reboot the pc by simply unplugging the power.
    Anyway, before doing any of the above, ensure your graphic drivers and motherboard drivers are up to date.
