Rename furniture?
This topic has been viewed 3591 times and has 2 replies
jimosity
Country: United States
Rename furniture?
Post by jimosity »
Is it possible to rename furniture?
It's difficult to find items and if I could rename them; it would make my life easier.
Looking for 'cabinets' and having them under 'lower cabinet' or 'grey cabinet' doesn't put all of them together - I'd like to organize better. Such as 'CABINET - lower', 'CABINET - grey', etc.
Re: Rename furniture?
For items in your plan (lower left pane), you can change names at will (also several at the same time). Select item(s) and change name. As for the catalogue(s) - upper left pane, the easiest is usually to switch between the two different display options (Preferences, Furniture catalog view): categories / search.
You can also use the Furniture Library Editor to change properties to installed libraries/collections. Typically this is used for personal furniture collections.
lama1980
Country: Polska
Post by lama1980 »
Sure, you can do it.
