I have already built the house model.
Also in this forum I found how to add the power plugs (with a custom design).
I would like to draw the tracks for the ethernet cables, thermostats, phone cables, TV and so on. It is 3D matter as the house has more then a floor.
I don't know how to achieve it, anybody can help me?
Thanks in advance
Electric & data tracks
This topic has been viewed 7356 times and has 6 replies
Re: Electric & data tracks
Have you tried the Create polylines button, in between the Create rooms button and the Create dimensions button?
Also available under the Plans option.
Hawk
I'll try, thanks.Have you tried the Create polylines button, in between the Create rooms button and the Create dimensions button?
Let us know if it works for you. If not, maybe some one can come up with a better idea. [:)]
Hawk
Create a level with the same elevation for each of your floors.
Use these to draw your cables and ducts.
You can hide them if you don't need them.
This is a good idea.Create a level with the same elevation for each of your floors.
I'll try this+polyline.
The Sweet Home 3D gallery's example 6 is full of different tubes. They are rather designed for the heater but it can help you.
