problem render become gray
This topic has been viewed 6586 times and has 3 replies
fhoofman
Post by fhoofman »
I have a problem while rendering photo.
here's the result.
any suggestion?
http://www.mediafire.com/view/x3mpst8f5v95ihy/BDS2.png
Re: problem render become gray
Looks normal enough to me.
When rendering in Q3 or Q4, the result should resemble a real-life colour representation. Surfaces with the same colour, will appear different due to the amount, angle and colour of light they catch, and the way they reflect it due to surface and shininess.
If you want an even white colour, use the lower settings Q1 and Q2.
fhoofman
Post by fhoofman »
Please have a look at the woman's head. Her head showed the wrong color
To minimize this effect you may try the following:
- change the shininess of the model - Modify furniture - Shininess - Matt
- change to lower quality setting Q3. if you need high resolution, make the image 1000x1000 pixels, then reduce to 500x500 pixels.
