Hi, I've got just two hours of experience with Home Sweet Home, so I'm as green as a cabbage! Though it does appear very easy.
Just wondering how I can build terrace walls, or balcony walls? When I add walls they are normal high walls, is it possible to add shorter walls? Or do I build the walls with icons?
I've looked for garden wall icons but so far have not come across any.
Thanks for any help.
Garden Walls
This topic has been viewed 3763 times and has 5 replies
- Jenniferbm55
- Country: Algorfa - Montemar, Alicante, Spain
Re: Garden Walls
If I understand your question properly, the answer is you can build both 'inside and outside' walls with the same wall too. Then right click on it to modify the wall height, width, and texture.
Re: Garden Walls
Maybe you should start by:
- watching the video tutorial
- reading the User's Guide
- using the in-built Help function
- exploring the program's menus and see if there's something useful for you
- Jenniferbm55
Re: Garden Walls
Thank you both very much. Have resolved this, I made the height of the walls 100 cm, and that worked great.
This program could be addictive!
- JUGGERNAUT
Re: Garden Walls
Hi Newbie,
Not "could be addictive", IT IS !!!
I am enjoying this addiction very much
Emmanuel, please do not create "rehabilitation" software for this addiction, as I will not use it
Leonard (Juggernaut)
Re: Garden Walls
Don't worry Leonard, I have plenty of other things to program.
And some of them are very addictive, at least for me when I test them! [;)]
More about it in the coming days....
