Hi there,
I have tried to set a light into a room, but I dont the same atmosphere as show in some picture of the website.
Is there a trick to do it?
Using light, how can I set ?
This topic has been viewed 2577 times and has 3 replies
Re: Using light, how can I set ?
It's difficult to give an advice without seeing any picture(s).
In general, if you want more or less realistic lighting of a room, you should:
- disable Add ceiling lights in the Create photo dialogue
- use large lights (e.g. 100x100x100 cm) at a low strength to give a basic light level in the room
- use smaller accent lights to indicate other light sources
- experiment, experiment, experiment.
Thank you for your quick replay, but I don't see any "add ceiling light" in the create photo dialog box.
move the quality slider to best then it will show add ceiling loght check box
