Good day everyone,
I am trying to draw a curved wall. Can anyone refer me to a previous thread/discussion on this please?
Thank you in advance
Juggernaut (South Africa)
curved wall
This topic has been viewed 9592 times and has 3 replies
Re: curved wall
While drawing
1 - Make your first click
2 - Press CTRL and keep pressed
3 - Make your second click
4 - Move the mouse to find the right curve.
Alternative (for more precision)
1 - Select wall
1a - If necessary change X,Y coordinates to desired location
2 - Use Modify walls
3 - Change value in Arc extent
1 - Select wall
- JUGGERNAUT
Re: curved wall
Thank you Hans.
I will do that tonight.
- JUGGERNAUT
Re: curved wall
Hi Hans,
I used your advice on changing the value in Arc extent and it worked perfectly!
Thanks again
Leonard (Juggernaut)
Thanks again
