Sweet Home 3D 5.2
This topic has been viewed 195870 times and has 43 replies
Re: Sweet Home 3D 5.2
You may want to check your textures. There's a longstanding advice that textures be no bigger than approx 1000 pixels wide or long. An 8 MB texture seems to be quite a big bigger than that.
HawkDawg
Country: Georgia, USA
Post by HawkDawg »
I had just finished adding the latest version of my largest 'furniture' model*; it contains a couple dozen defined materials, of which I remap at least half to a new texture. I know in at least one case I made use of a self-referential texture -- that is, under 'Materials,' I opened a defined texture, selected the existing texture in order to add it to the array of thumbnails, and clicked 'OK'; I then opened another material definition, clicked 'Texture,' and selected the thumbnail I previously added.
It sounds like; by adding that new texture to an existing array of thumbnails, SH3D decides it's a new sub-compilation of the original, creating a sub-directory of the original instead of just updating the original.
Hawk
enkonyito
Post by enkonyito »
Concerning the new photo renderer properties, I made tests with SweetHome3D-5.2.beta1-windows.exe and the SimpleRoom.sh3d file.
Can the following renderings match what could be expected with the indicated parameters?
Common settings: antiAliasing.min = 1; antiAliasing.max = 2; filter = blackman-harris. The times are given on an indicative basis.
BucketRenderer
samplerAlgorithm = bucket; rendering time : 01mn 25.56s
SimpleRenderer
samplerAlgorithm = fast; rendering time : 06.49s
ProgressiveRenderer
samplerAlgorithm = ipr; rendering time : 11.38s
MultipassRenderer
samplerAlgorithm = multipass; rendering time : 01mn 49.45s
For information, the final rendering and its duration is similar with the parameters antiAliasing.min=0 and antiAliasing.max=0 for samplerAlgorithm=fast, ipr or multipass.
EnkoNyito
My results for this test:
Computer: Windows 10, 6 cores
SH3D: v5.2 b1 with 3.6 GB allocated
Plug-in: Advanced settings for photo rendering v1.3
Default settings: Q4 (including 1/2 AA, blackman-harris)
Variable settings: sampler
bucket: +/- 7 seconds (= default settings for plug-in)
fast : less than 1 sec
ipr: less than 1 sec
multipass: not available (where did you get that?)
Additional tests
global illumination: default, diffused bounces: 1 --> +/- 7 seconds (= default settings for plug-in)
gi: path, db: 1 --> 2:58 min (worst result of these 3 tests)
gi: path, db: 2 --> 6:20 min (best result of these 3 tests)
enkonyito
Post by enkonyito »
My configuration : CPU 2 cores, SH3D 0.6 GB max.
For samplerAlgorithm=fast, do you have the same type of rendering?
The multipass parameter is not yet integrated into the plug-in because it is not indicated in the PhotoRenderer.properties file.
As the MultipassRenderer.java file is present in the source code, you can test it with a SweetHome3D.l4j.ini file by adding -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.samplerAlgorithm=multipass .
EnkoNyito
santbose
Country: Maharashtra, India
Post by santbose »
How do you allocate in SH3D as you mentioned you have allocated 3.6GB Hansmex. Can you please help me in this.
Please, read the FAQ, especially the section on the XMX trick.
Here's a second Beta version.
As the first Beta version didn't resolve the issues of some Windows 10, I also prepared a Windows installer bundled with Java 8u72 released a few days ago. Hope this time it will work better.
I was able to fix the other issue reported by Mazoola. Many thanks for your detailed report, it was very helpful. I didn't realize it was possible to reuse the textures of a piece of furniture through the recent textures list, nice trick! [;)]
This version fixes also a bug that prevented to change the proportion of the photos at the two first quality levels.
Finally, it brings the two following improvements:
- the width of a door or a window displayed in the plan takes now into account the width of its [font=courier new]doorOrWindowCutOutShape# [/font] property. This can be tested with the files fermette_02.sh3d and windows_etc.sh3d designed by OKH.
- I added an Invisible radio button in Furniture materials dialog box to make a material invisible and hide the parts of a model that uses it. Using this option will avoid the "ghost" issue that appeared on photos when you used the invisible texture trick.
Emmanuel,
Just downloaded 5.2 b2 and it works fine under W10.
Invisible texture works fine as well. Invisible parts don't cause shadows in Q4. VERY nice feature!
Quick test:
Tried the Win10 installer, beta 1 installed without a glitch, however, now with
Version 5.2 Beta 2 Java version 1.8.0_72 / 64 bit / 1.8 GB max
I get "The signature of SweetHome3D-5.2.beta2-windows.exe is corrupt or invalid."
It is still possible to install b2 if you ignore a barrage of Win attempts to prevent you from installing. Don't know whether this comes from beta2/Java 8u72 or some annoying Windows update (it updates non-stop). (Win 10 Home, Cumulative Update for Windows 10 Version 1511 for x64-based Systems (KB3124262). - apparently up-to-date as of today).
width of a door or a window displayed in the plan takes now into account the width of its doorOrWindowCutOutShape# property.
Very nicely implemented, and certainly makes it easier to make door and window models.
Love this feature, especially that later exporting the model removes the element marked invisible. Very useful if you want to remove parts of a model. But I suppose that means that it is not possible to set invisible in the .mtl file (as a sort of default - hidden element)? Not that it matters, better to be able to remove.
However, with a candlestick (model with candle and lightsource) I could indeed remove the candles by setting to invisible. But the candles reappeared in the 3D view when I added more furniture (still marked invisible, and exporting still "removes" the invisible part completely). This happens both under win81 webstart and win10 installer. Sent you file with misbehaving model. Could it be the lightsource, because it does not happen with other models I tried, or is it because I removed an extremity of the model? Will test more later.
