Comparative global illumination
This topic has been viewed 41722 times and has 26 replies
enkonyito
Post by enkonyito »
By default, Sweet Home 3D uses global illumination "ambient occlusion".
Image Image
Indirect light reflected by objects can be simulated by setting global illumination to "path".
Image Image
The rendering will be longer.
EnkoNyito
HawkDawg
Country: Georgia, USA
Re: Comparative global illumination
Post by HawkDawg »
Where do you change this setting?
Hawk
enkonyito
Post by enkonyito »
By using this plug-in .
More info about it here .
EnkoNyito
HawkDawg
Post by HawkDawg »
Thanks. I have that plugin installed. I know what you're talking about now.
Must have been a senior moment that it didn't dawn on me. [:))]
Hawk
Recently, I upgraded my PC, so it's much faster now. Therefore I decided to play around with this photo plug-in. Unfortunately, I can't figure out how it works.
Am I correct in thinking that this plug-in has effect only when making a render in Q4?
HawkDawg
Post by HawkDawg »
I believe it works in Q3 and Q4.
Hawk
enkonyito
Post by enkonyito »
Hans, Hawk,
Version 1.2 of the plug-in incorporates some additional information like an illustration quality levels and a small parameters definition.
Hans:
Hawk:
It is used as a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties at the two best quality levels (Low/Q3 and High/Q4).
Hans:
I should perhaps make a tutorial like plug-ins and extensions User Guide .
Regarding global illumination "path" , a sky with texture can give a rendering dark, powerful lights can give a dazzling rendering.
Enko
EnkoNyito
HawkDawg
Post by HawkDawg »
That's the one I have. [:)]
Hawk
enkonyito
Post by enkonyito »
A tutorial explaining the use of the plug-in is available here .
EnkoNyito
santbose
Country: Maharashtra, India
Post by santbose »
Hi Enkonyito,
I have downloaded the plugin 1.3 and using the portable version of SH3D 5.1. But am not able to select the filters and Sampler Algorithm. Neither the option Create photo with advanced render properties is working. Can you please help me and guide me how to use the plugin. I am doing a large scale project for my client.
Users browsing this forum: hansmex
