confused Sauna interiors
This topic has been viewed 21940 times and has 4 replies
MimicaDreamer
Sauna interiors
Post by MimicaDreamer »
We want to go Sauna but I am not to able to do interiors. More specifically the "kiuas" "lauteet" I did even find the words, so I move for you, my House Master, this big problem. [:x]
I hope that the link opens - It is not necessary - but beautiful.
HawkDawg
Country: Georgia, USA
Re: Sauna interiors
Post by HawkDawg »
I'm not sure why your link doesn't open but it's probably because you didn't use the http BBCode url tags, but here it is.
Sauna Shot
That is a nice looking sauna.
Hawk
Re: Sauna interiors
- as image, no, but as link it works. And, yes, very nice.
Kiuas / lauteet translate to stove / benches - if google-translate does not deceive. In which case doing a 3D Warehouse search for sauna ought to help you find interior. Also playing around with the words sauna and stove - and sauna and bench could give usable results.
For modern saunas there are certain standards used, such as having the door on the same wall as the stove, where the ventilation should be placed and drainage. Also, the door must satisfy certain safety requirements so you are not locked in. Walls should satisfy certain minimum insulation requirements (something in the range of 100mm insulation + pine panel as extra layer against inner wall). But there are several handbooks available that will give you the details from the major sauna suppliers.
PS. There is a Sauna kit (tiny tiny) in SF 3D models 370 - and some wood textures in SF 3D models 335 - just simple, seamless textures to illustrate (and keep model small).
MimicaDreamer
Re: Sauna interiors
"BB Code url tags" and other mystery curler...hmm...One day I will show to world, I´m flying like a eagle and it is even easy.
She thought to say, at thank you both again for your big good work to find all this to me. The word-case was most fun. I knew those words Stove and Bench, but I didn´t belive that the words does mean the Sauna fittings too.
She bob a curtsy to the master.
DVMattson
Country: Wisconsin, USA
Re: Sauna interiors
Post by DVMattson »
I grew up with a Sauna for 18 years until I moved away to attend college. External building with 2 rooms. Now to set it up on Sweet Home 3D and show it off. First, find a stove with rocks. [;)]
