Furniture Library editor shows nothing
This topic has been viewed 4826 times and has 4 replies
turbokey
Post by turbokey »
Hi! Importing a furniture library onto the program doesn't take any effect onto the furniture window. I can see the file is copied to application data\... folder but SH3d doesnt see nothing new, just the default library.
Also, when I try to see an external library, like Contributions.sh3f file using Furniture Editor, it doesnt show nothing too. What can I do? :(
Using W7 SP1.
Re: Furniture Library editor shows nothing
Did you try with a smaller library?
turbokey
Post by turbokey »
Thanks Emmanuel. Tried LucaPresidente.sh3f (89 models) and Trees.sh3f (7 models) files and got the same results, like the screenshot.
Try to launch the following command in a command window:
java -jar C:\FurnitureLibraryEditor-1.17.jar
(to get the right path of FurnitureLibraryEditor-1.17.jar file, just drag and drop its file icon in the command window).
When the bug happens, some text reporting an exception should appear in the command window. If you could copy/paste that text, it would be helpful.
turbokey
Post by turbokey »
Tried and nothing special happens on command window :(
