Flip door
This topic has been viewed 59225 times and has 5 replies
Flip door
I know how to rotate a door, but how do I flip the door, so the door swings DOWN instead of up? Thanks,
Re: Flip door
My guess is that you want to know how to open the door in the room and not, say, in the hallway?
When placing the door, wiggle a bit with your mouse. You will see that the door can be inserted opening towards either side of the wall.
Re: Flip door
I can rotate the door 360 degrees, and I can re-size the door, and I can move the door. If I open the door and stand with my back to the hinges, and if the door is on my left, it is a left-hand door. I have a right-hand door, and I need a LEFT-HAND door. "Wiggle a bit" doesn't seem to work.
Re: Flip door
Then most probably you need Modify furniture --> Mirrored shape and (un)check the little box.
Re: Flip door
Got it, thank you.
Re: Flip door
Good suggestion. As it is not furniture, just didn't seem that obvious! Thanks.
