Sweet Home 3D 5.0
This topic has been viewed 1525375 times and has 115 replies
YGYL
Re: Sweet Home 3D 5.0
Post by YGYL »
NEW BUG 2 > □
ImageOriginal Picture
It's probably the character "²" that is missing in the font you chose.
YGYL
Post by YGYL »
If you can ,then not find "²" in the font,specify a default "²" would be better.
I wanted to release Sweet Home 3D 5.0 tonight, but can't tag the version in the source code and can't upload installers on SourceForge.net because most of their services have been down for almost one day!
That's why I prefer to host the released files on sweethome3d.com for the moment.
You can download them with the following links:
[Removed old links, go to https://sourceforge.net/projects/sweeth ... ome3D-5.0/ to download the files]
Once SourceForge.net will be repaired, I'll upload these files there and will make the release more official on sweethome3d.com.
Thanks for your patience...
Thank you once again for a great job !!
As upload service won't still be available on SourceForge.net before a while, I officially released Sweet Home 3D 5.0 files on sweethome3d.com tonight.
Released files will be copied at SourceForge.net, once their service will be back.
Note that the files I released two days ago were updated under the same name at 19:23 CEST on July 19, to fix a bug I found on the visibility of doors and windows in layers lower than the one they belong to. Sorry for any inconvenience redownload may cause.
Thanks for your tests and your great support! [:)]
YGYL
Post by YGYL »
From the old version to the present, there has been a translation error
新建墙体厚度(F) change to 新建楼层的楼板默认厚度(F)
yancan
Post by yancan »
Hello Emmanuel,
great piece of software by the way!
Do you have any idea when the portable version of V5.0 will be made available?
Best regards.
Probably not before mid August. The missing data are some sh3l additionnal translations that contributors might have difficulties to update because of SourceForge problems with CVS and other repository features.
But you can update the existing portable version 4.6 to 5.0 by yourself: download one of the Linux installers of version 5.0, uncompress it to get the lib/SweetHome3D.jar file it contains, then replace the file with the same name in the portable version with the 5.0 version file you extracted. That's all!
yancan
Post by yancan »
Merci beaucoup pour cette technique d'upgrade manuelle !
Cordialement.
