I've been using "create dimensions" to measure items, to get them a certain distance from the wall for example.
When I'm done with the dimensions, how do I get rid of them?
How to delete remove hide dimensions
This topic has been viewed 6136 times and has 7 replies
oakland602
- Country: Oakland, California, United States
Re: How to delete remove hide dimensions
Try this:
1 - select dimension
2 - press Delete
2 - press Delete
oakland602
Thanks Hansmex,
I'm needing some help with step 1. How do I select dimension? Every time I try it, I end up moving my floor or something else. I've tried clicking on the numbers with the select tool, and I've tried using the dimension tool. What am I missing?
Don't click on the number but on the lines themselves.
oakland602
Perfect! That's the trick.
Thanks! Love the software.
Is there a way to select ALL dimensions?
Not that I know of.
The best way to handle this is to always put all dimensions on their own (same elevation) level. That way you can show/hide the level with dimensions or completely delete it.
You could select all the dimensions with Select Hide utilty plug-in developed by Dorin.
